Other Interest > DIY - Side Scan Sonar and towfish
Solix Towfish
(1/1)
nrgbentall:
I see people have had successful results using cat 7 cable with the Helix to make a tow fish, but with solix transducers you have more wires as it doesn't have a common ground for each element. It also has a separate element for down imaging and transducer identification wire
So it looks like you need 9 cores cores if you use the shielding as a ground and forget the temp
Cat 7 cable is four twisted pairs so 8 cores and a shielding but that means 1 core can not be connected.
If you don't connect the 2d element, or the Identification wire does the transducer still work on SI and DI?
Any help, much appreciated as I really like having the extra DI element and the touch screen of the Solix
Thanks Nick
Rickard:
Hi Nick,
I think few people have made that kind of cable extension with a Solix. There is a risk you won't get any reply from the Solix people. I have some experience with older models; the M37, 981 and 999, but not with the Solix or Helix models. My units can operate with almost any configuration - no temp, missing channel, transducers from other manufacturers etc. Sometimes the unit will report something like "no transducer" on startup, but all my units can be forced to start manually. There should be such an option also in the Solix. I think you can omit transducer id and temp. You can probably make the unit operate properly with manual settings of transducer type, frequency etc after startup even if the unit protests.
I would start with a test. Connect all pins, except those for temp and id using test cables between the unit and the transducer cable and see what happens. (The pins may be tiny, so you may have to make your own test cables. I use pins from old computer cable connectors in my experiments.)
Remember, Cat rating of the ethernet cable doesn't matter, but shielding does. A well shielded and cheap Cat 5 cable will do the job as well as a new expensive Cat 7 cable.
Regards, Rickard
Navigation
[0] Message Index
Go to full version
