Model: | ALL SI Models |
Suggested Upgrade: | iPilot Link Dongle |
Explanation: | There is a need to reduce the price on the link system to increase sales volume of both iPilot Minn Kota trolling motors and Humminbird systems. System prices are quickly getting out of the range of the vast majority of anglers and making it only affordable to Pro anglers and wealthy boaters. The solution is to make a small inexpensive dongle that connects to the ACCY-COM connection that will work like/and is an actual remote control. The remote control will be associated to the trolling motor and the follow the contour guidance control is the SONAR/fishfinder control head/AS GPS HS when the follow the contour feature is turned off in the SONAR/fishfinder. Software adjustment have to be made to accommodate the configuration changes.This is not the optimum set-up, which would be the more costly iPilot Link, but it will work and add value while producing sales from a broader range of anglers. |
Added in Software Version: | |
Comments on Update: |
