I have fooled with this for six weeks and I give up.
I collected several sets of recordings. The results is always the same.
SON2xtf says my R*.DAT is not valid.
HBSI says there is a "unhandled excpetion" with these details:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IndexOutOfRangeException: Index was outside the bounds of the array.
at HBSI_Sonar_File_Converter.Form1.OpenMenuItem_Click(Object sender, EventArgs e)
at HBSI_Sonar_File_Converter.Form1.LoadButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3074 (QFE.050727-3000)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
HBSI Sonar Data File Converter
Assembly Version: 1.0.1.3
Win32 Version: 1.0.1.3
CodeBase: file:///C:/Program%20Files/HBSI%20Sonar%20Data%20File%20Converter/HBSI%20Sonar%20Data%20File%20Converter.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Configuration
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
It does not matter whether I take the data from the cards or copy to hard drive, this is what I always get. I down loaded examples from the web and they work in the software on my machine so yellowfin, hbsi, and the other software works on my machine. It is that my data from my cards doesn't.
What gives anyone?
IT WORKED! IT WORKED! IT WORKED! IT WORKED!
I REINSTALLED 45.1.0 FROM A NEW DOWN LOAD. MUST HAVE BEEN SOMETHING LIKE POLITICS, CORRUPT!
THE PHOTO IS THE BEGINNING OF THIS LAST TRIP, 135 MILES TO WATER, UGH. TOO MUCH WEIGHT FOR THE NARROW AXEL ON THE TRANSOM, 300 POUNDS OF BATTERIES, GAS AND MOTORS. BENT THE COUPLER ON THE TURN AND WENT OVER. COUPLERS ARE $18 FROM WAL-MART, $8 FROM HARBOR FREIGHT.
USED MY AAA RV CARD AND GOT TOWED TO WAL-MART AND WAS AT THE LAKE 5 HOURS LATER THAN PLANNED. NOTICE THAT MY HARD WOOD COVERS THAT I SECURE ON THE TOP OF THE BOAT BETWEEN GUNNELS KEPT THE 7 TACKLE BAGS AND 12 VERY EXPENSIVE RODS INSIDE. MY THREE POINT SECURING SYSTEM KEPT THE BOAT MOUNTED TO THE TRAILER I SEE TOO. IT IS A STARCRAFT 14.5 STARFISHER OR SOMETHING LIKE THAT, DEEP V WITH A FLOOR AND LIVE WELL, ALL TILLER CONTROL. I AM A NORTHLAND FISHERMAN AND PREFER TILLER CONTROL.
I GOT 5 GALLONS OF GRAVEL INSIDE TOO!
I AM GOING BACK AND RE-LIVE MY SONAR TRIP ON YELLOW FIN, SEE YOU ON THE WATER!~ PP
(http://img299.imageshack.us/img299/8603/theadventuresoffisherma.jpg)
