Miscellaneous => Everything Else => Topic started by: freezerfiller on February 05, 2013, 10:20:23 PM
Have a tablet and don't want to take it out on the water for fear of getting it wet/salty/sandy? I've been doing this for 2 years now, and I thought I'd share. If you have a foodsaver or other similar food storage system, you can put your tablet in a bag, provided your system offers a smooth side, and seal it up. You can't charge it, or plug anything into it, but if you just want to use your navionics app, or read a book on the boat/beach, this is the ticket. The touch screen and buttons work like a charm. I don't pull a full vacuum, just enough to lay the plastic smooth on the screen. If you pull too much vacuum, your buttons may stick...
And it will probably cook itself in that bag ..... >:D
Straw
Havent had an issue yet, and I've had it out on the boat and the beach several times, but I can't say I've left it in direct sun for an extended period.
cool trick sir
thank you
Have you tried using a freezer grade zip type food storage bag?
Which tablet you got? I’m running a Samsung Galaxy 10.1
My daughter has the ASUS transformer, and I have the kindle fire HD. It is likely going to become my wife's as It doesn't have a gps in it, but I like it otherwise. I haven't tried ziploks, but as long as you can get enough air out to keep smooth contact across the screen, they should work.
I have a galaxy tab. will try it out this weekend. Thanks for the tip.
I used a Zip-Loc Bag with a Acer 300 in it had heat build up problems. This was in South Carolina in april.
Roddy
I guess I should have mentioned this won't work on tablets with heat sinks/fans. It does work on the galaxy as my brother and I used his for the navionics app on our last gulf trip....and it was hot as it gets outside.
Worked well on my galaxy. Thanks again for the tip
