Side Imaging Forums => Helix Series Units => Topic started by: wisconsin chad on March 23, 2019, 10:08:52 PM
Title: 10 mega di g2n not taking new update
Post by: wisconsin chad on March 23, 2019, 10:08:52 PM
Hello, i have mega di 10" g2n and it will not take the software update 1.9. I have the right update and tried different cards. I let the graph load and exit it out and then put my card in and it does nothing. My mega si 10" g2n took its sofware which is seperate. Can someone please help, the reason i am updating is because my di ducer on my 112 ipilot doesnt show the di screen but it shows 2d
Title: Re: 10 mega di g2n not taking new update
Post by: ezfishn on March 23, 2019, 11:53:00 PM
Did you reset defaults on unit before inserting the SD card?  Might try a different card slot and make sure no other cards in unit.
Post by: wisconsin chad on March 24, 2019, 08:27:01 AM
I did that but i just remebered i tried to download the si update to to the di graph and then seen that there were a update for each graph. Would this mess things up?
Post by: ezfishn on March 24, 2019, 09:02:15 AM
The unit should only recognize the correct update file.  If you had the wrong file on SD card, it wouldn't do anything as described.
