Side Imaging Forums => 898c SI => Topic started by: ChipsXJ on December 21, 2012, 11:49:39 PM
Can a 798ci HD si use/share the transducer connected to a 898ci HD si if both units are networked using Ethernet system?
Do these 2 units share data/features well? (are they good networkable partners)
I believe you can share most features except map cards.
Works. You can share everything except map cards. One item of note. The 798 unit and TD do not use/have 800mhz. So when the 898 is using the 798s TD via the ethernet settings you only get 83/200/455. When the 798 is using the 898s TD again you only get 83/200/455 since the 798 unit isn't capable of the 800 freq.
What I have in my boat. 898 console/stern TD mount and a 798 bow/TM TD mount.
