Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: promapper on May 05, 2013, 08:21:13 AM
Title: Importing data from SD card to 997 or 998...TIP/TRICK
Post by: promapper on May 05, 2013, 08:21:13 AM
I was not able to find a way to upload the data to the control unit from the card.
Both the 997 and 998 failed to load the waypoints from HBPC into the control unit.  Everything i looked for said that the units should just "load it or "see it".  never happened on either unit.
Then I did a google search which led to the following link Where Hummer Greg suggested inserting the card with the unit powered up:  POOF ! Typical Greg Magic!  THANKS GREG
link for reference
http://forums.sideimagingsoft.com/index.php?topic=4061.0 (http://forums.sideimagingsoft.com/index.php?topic=4061.0)
Title: Re: Importing data from SD card to 997 or 998...TIP/TRICK
Post by: Humminbird_Greg on May 06, 2013, 03:38:03 PM
This was a programmed change to the units some time back promapper.
Good reminder though.
