Our Community => Personal Pages => dybvad417 => Topic started by: dybvad417 on April 21, 2009, 07:28:51 PM
Title: My boat and my Humminbird 987 Cx SI
Post by: dybvad417 on April 21, 2009, 07:28:51 PM
Here is my boat.  Nauticat 25 "Minicat" long keeled. New engine 3. cyl. Beta 25 diesel.
My project is to install a Humminbird Sidescan.
No one in Denmark can help me because it have never been done before.
More pictures vill follow.
Title: Re: My boat and my Humminbird 987 Cx SI
Post by: Jolly Roger on April 22, 2009, 03:34:28 PM
Blast!!!
That's more or less the same thing I'm doing on my boat at the moment. Nice work from what I can see on the pictures. I mounted my "telescope" at the transom. Used 3/4 and 1/2 inch pipes and a jack plate to mount the transducer. For guidance I cut the 3/4 pipe for the length of the lift way and screwed a 6 mm screw in the 1/2 inch pipe.
I had a SAGA 20 (similar to yours) before I got my current boat. There I made a bracket to mount the ducer (EAGLE SUPRA PRO) at the drainage plug at the keel and drilled a hole in the plug to route the cable through. I had to cut the cable, but soldered it and had no problems after. Sealed the hole with epoxy and that lasted for over three years until I sold the boat without any leakage.
I'll post pictures of my "project" as soon as I finish it.
Nice craft manship dybvad417!!
EDIT: Looks even better with the new pictures.
SO THEREFORE HEREWITH DECIDED AND ANOUNCED:
As soon as I am the King of Germany, you'll become the
KING'S OFFICIAL TRANSDUCER MOUNTER!!!
Post by: reso on July 25, 2009, 06:45:30 PM
When I look at it, I think you only see one side....the boat is blocking the view to the right isn't it?
reso
Post by: reso on July 25, 2009, 06:46:44 PM
I guess you lower the pole down when you are scanning... ::)
Post by: Jolly Roger on July 26, 2009, 02:52:28 AM
Right Reso,
the transducer can be lowered for scanning.
The "Telescope" has the advantage that you can lower the ducer at slow speeds for scanning and raise it for high speeds in order to get at least a good 2D view and decent depth readings.
Here's my Telescope:
http://forums.sideimagingsoft.com/index.php?topic=158.0 (http://forums.sideimagingsoft.com/index.php?topic=158.0)
Regards
Harry
Post by: Kimi on February 20, 2010, 11:28:10 AM
This is the best mounting I ewer seen!  :D
Sometimes something like that crossed my mind too, but I didnt got the guts to penetrate the hull.
Please be careful, dont hit anything like a rock, or submarine whit your boat !
Kimi... ::)
Post by: sonar2000 on February 20, 2010, 01:32:02 PM
OK I was going to post my pictures of our flexible mount but after these pictures mine will look like the project from hell.  Great craftmanship.     Chuck
Post by: keizerh on February 20, 2010, 05:50:44 PM
Here is my flexmount.
http://forums.sideimagingsoft.com/index.php?topic=263.0 (http://forums.sideimagingsoft.com/index.php?topic=263.0)
hendrik
