Side Imaging Forums => 798c SI => Topic started by: crappie60 on July 04, 2014, 09:23:16 PM
I have way points and recordings on the unit but I cant get them on the nave card I have a 798ci hd si unit the manual says go to nav tab and highlight Export all nav data , but I don't see this option listed on my nav tab menu. any help would be greatly appreciated
Crappie60,
Screen Snapshots and Sonar Recordings are always saved on the SD memory card.
Exporting the waypoints from your 798ci HD Si unit changed with a change in the unit software Try this instead:
- Press the MENU button twice and go to the “Waypoints, Routes, tracks” menu.
- Open this menu by using the Right Arrow.
- Scroll up to “Options” and open it using the Right Arrow.
- Select “Select All and…” and use the Right Arrow to open this submenu.
- Select “Export” and use the Right Arrow to activate this menu.
Thanks Greg, I tried your info and found the right menu thanks again
