Author Topic: Request for sample records  (Read 989 times)
Offline zebu
« on: January 12, 2022, 09:47:43 AM »
Hello,
I am planning a lake mapping project in a few days and I wonder if someone could share some sample recordings in order to check that all my wiring and tools are ok.
I use a 898c SI, actually with 5.410 firmware version, but I can update the firmware if needed.
I want to play back the recordings from the 898 attached to a computer with mapping software (Reefmaster / Hypack) in order to check that communication and data acquisition are correct.
Moreover, I would be able to use the recordings directly onto Reefmaster in order to familiarize with it before going on water.
If someone can share some recordings (898c SI model would be perfect, but maybe other sources should do the trick, at least for reefmaster), it would be very helpful to me.
Thank you.
Xavier
Re: Request for sample records
« Reply #1 on: January 12, 2022, 10:09:02 PM »
I have some 1197 recording  ... but they most likely will not play correctly on an 898 because of screen resolution difference  ... I’m not sure about Playback in Reefmaster  ...
PM me an email address and I think I can get some loaded thru transferbigfiles.com  ...
Offline zebu
« Reply #2 on: January 13, 2022, 04:04:44 AM »
Thank you, I think it would help in any case.
(do you know which firmware version do you have on your unit ?)
If more forum members have sample recordings and are ok to share them, I could share an upload link that permits to send files directly on my server, without using any "public" server as bigfiletransfer, wetransfer...
Doing so, there's no need to exchange email etc.
Thank you all.
Last post January 10, 2012, 12:56:26 AM
by T.G
Last post April 22, 2012, 07:18:25 PM
by fishshtick
Last post March 29, 2013, 03:16:24 PM
by Kokanee
Last post January 02, 2012, 11:22:45 AM
Last post April 05, 2012, 05:06:23 AM
by Milieucel
Last post March 21, 2013, 08:41:01 PM
Last post February 20, 2014, 02:08:23 PM
by cdub
Last post May 08, 2017, 08:37:41 AM
by John M
