Other Humminbird Products => GPS Chartplotters and Non-SI Humminbird Units => Topic started by: mustang-alkie on August 04, 2012, 04:33:19 PM
Title: 767 starts out reading right then goes crazy
Post by: mustang-alkie on August 04, 2012, 04:33:19 PM
i have this unit on the front of my boat. like i said it starts out fine the the temp and voltage start reading off the wall readings. temp drops to -3 deg. , and the voltage goes to 16+ volts. it takes it about an hour of usage before it starts. any ideas would be great.  Thanks
Title: Re: 767 starts out reading right then goes crazy
Post by: Roddy on August 04, 2012, 08:02:17 PM
Tang, Sounds like a 12VDC power falt. Run the wire, Clean the plug and check the pins.
Good Luck.  Roddy
Post by: mustang-alkie on August 05, 2012, 07:56:41 AM
I will look at the wires but I dosent do it with my 587?
Post by: sonar2000 on August 05, 2012, 12:28:26 PM
could be the connector pins on the specific unit. check the plugs..
Post by: Humminbird_Greg on August 06, 2012, 03:22:08 PM
Is this with the 587 unit connected to the same mount and run at least an hour as well?
Post by: mustang-alkie on August 06, 2012, 05:51:21 PM
The 587 will run all day with no problems.  I put the 767 in a buddies boat, the only thing we saw was the temp not read right. I don't know how to check the connections other than to open it up. Is this what I should do?
Post by: Humminbird_Greg on August 07, 2012, 11:00:47 AM
NO!
All you should do is look at the connectors on the backside of the unit and see if you can tell that the sockets are malformed or larger than those on your 587 unit.  If they are, then let the Humminbird Service folks know this.  If they aren’t, then you are still faced with sending your unit in to them to be tested and worked on.  If you can provide any additional information to help them pinpoint the problem you should (Ex: it only happens on sunny days over 95 degrees, it only happens when the water is rough,…).
Post by: ITGEEK on August 08, 2012, 08:28:07 AM
Is your 767 and 587 hooked to the same battery?
If not, then fully charge and load test the battery
hooked to the 767.
It doesn't matter when you bought the battery,
or if you KNOW it's good.
Get it tested.
Post by: mustang-alkie on August 08, 2012, 09:39:07 AM
It's on the same battery, I have not had it checked but my 898 is on the same battery and is working fine.the connections look good to me so I'm not sure but I'm starting to think there is just something wrong with the unit.
Post by: ITGEEK on August 08, 2012, 11:20:17 AM
If you have an inline fuse, you may want to check it for
corrosion, and the connections there.
Other than that, it might be time to send it in.
