Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: tonyr on November 09, 2009, 07:38:34 PM
I am in the process of upgrading from an older Matrix unit to something like the 997. Looking at the specs, I cannot see what the amps draw might be for a proper chartplotter plus SI function. I assume it is much more than the little Matrix, but just how much is the question.
I have a 50 h.p. Yamaha, and it has perhaps 6 amps available. Is this enough?
Thanks, Tony.
According to the Humminbird web site the 997c Si unit draws about 800mA.
http://www.humminbird.com/support/FAQ.aspx?faqid=499 (http://www.humminbird.com/support/FAQ.aspx?faqid=499)
Your motor can provide about 5.2 Amps more than what the 997 unit will need, so you are good.
[1,000mA (milliamps) = 1.0 Amps]
Just be sure to use the heavier gauge power cable that comes with the 997 unit when you install it.
