Software and Software Development => Software Downloads => Topic started by: ogeecheedawg on February 09, 2011, 02:12:21 PM
Title: SD Card (The media is write protected)
Post by: ogeecheedawg on February 09, 2011, 02:12:21 PM
I'm new to this kind of thing and everytime that I try to personalize my profile or try to update the new version on my SD card it says error and (the media write is protected.
 Do I need a specific type of SD card and reader/writer?I picked up one from the local wal-mart.
Title: Re: SD Card (The media is write protected)
Post by: RGecy on February 09, 2011, 02:53:26 PM
Ogeecheedawg,
Welcome to the forum.  Most likely the write protect slide on the SD card got accidentally moved to the locked position.  Just slide it back and you should be fine.
However, I do recommend purchasing a better SD card like the sands extreme III.  The perform extremely better when recording on the unit, and tend to be much higher in quality.
Do some searches here on the forum for SD card and you will find a lot of good reading.
Hope that helps.
Post by: ogeecheedawg on February 09, 2011, 03:13:12 PM
I tried that and I even went and bought a better card but it's doing the same thing.
Post by: RGecy on February 09, 2011, 03:41:44 PM
What are you doing when you get this error?  Is this on the unit or when you are in Humminbird PC?
Have you tried formatting the card?  And what brand and size card are you using?  Is it SDHC and do you have an SDHC card reader?
Post by: ogeecheedawg on February 09, 2011, 04:23:01 PM
It is in Humminbird PC when this problem occurs.Whenever I try to personalize the text on the SD card it throws the error and I was trying to load the new upgrade to the card and it throws the error.
 It is a 4gb SDHC Optima card and the Card reader/writer is sd/sdhc/mmc capable.
Post by: Humminbird_Greg on February 09, 2011, 05:20:17 PM
Try again but with a different memory card.  We recommend the SanDisk brand as they follow the SD Card Associations specifications (not all SD memory card manufactures do).
Post by: ogeecheedawg on February 09, 2011, 05:37:37 PM
I just tried it with a Sandisk 2gb card and it's the same thing.Pretty frustrating.
Post by: Humminbird_Greg on February 09, 2011, 05:45:10 PM
What version of HumminbirdPC are you running?
You can download the software directly to the SD card and not use HumminbirdPC at all.
Post by: ogeecheedawg on February 09, 2011, 06:02:59 PM
Humminbird PC is 3.2.2
Post by: sonar2000 on February 09, 2011, 06:25:28 PM
Upgrade to the unit should always be the sd card first....unless you do not have a unit with sd.
then you will have to use the HBPC connection....
chuck
Post by: Bob B on February 09, 2011, 08:04:36 PM
What software do you have on your PC?
I saw another post where a guy had the 64bit version of Win 7 Pro and had similar problems with the new version of HB PC.  (I think the application was locking up on him when trying to write a file.)
I think he was able to get around it by somehowe running the app in 32 bit mode.
