General => General Discussion => Topic started by: lcookie on April 23, 2012, 09:19:00 PM
I have a 10 ft cable permanently mounted in my boat. Does HB (or another company) make a male/male adaptor to connect two shorter cables together?
Hi Icookie
If you mean cable with RJ45 plugs, the adapter must be crossed throughout between input and output. Ask on the computerstore or check the possibility to use a Ethernethub.
mvh
Rüdiger
Humminbird only sells the Ethernet extension cables. They have the M12 8 position Ethernet type connectors on them.
Thanks for the info Greg.
