Side Imaging Forums > 598c SI HD
598ci Navigation Grid
rnvinc:
Page 162 here describes NMEA as connecting to an autopilot ...:
https://www.humminbird.com/sites/humminbird_site/files/hum_productmanual_ops_598cihd_532077e.pdf
I have no experience with the autopilot ... but here is a video ...
https://youtu.be/wX07i0g39L4
rnvinc:
“Continuous Navigation” mode and “SI Navigation” mode are features used in the GOTO function of the core SI units ...
Page 146 of the same manual ...
Swann:
Very Thorough my friend & although I do have a manual, H-B Service should have U as their top consultant - LoL ! BTW I picked up a 2nd hand XNT9 HDSI 180T last nite after work & was hopeing 2get a chance 2do some comparisons w/the XNT9 SI 180T that came w/my 598ci BUT the question is: How would I be able 2do an S.I. comparison "simultaneously" where I might have 1 scanning Left Side & the other reading Right Side? Or is the best I can do is have them on each side of the motor & switch plugs. I did manage 2 negotiate an SI DB Y-Cable in2 the deal But I would still be "swapping plugs" in that scenario as well? Any ideas? Thanks
Swann:
Ok, No Need 2answer that question as I just learned from browsing the web that I would need an SI LR Y-Cable 2accomplish that last question. Cheers ;)
rnvinc:
--- Quote from: Swann on May 05, 2022, 09:47:13 PM ---Ok, No Need 2answer that question as I just learned from browsing the web that I would need an SI LR Y-Cable 2accomplish that last question. Cheers ;)
--- End quote ---
You are correct my friend ... and your older core unit can use the newer M 9 SILR Y cable or the older AS SILR Y cable ...
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
