Side Imaging Forums => 1197c SI, 1198c SI & 1199ci HD SI => Topic started by: wpda on July 29, 2010, 01:18:37 AM
Title: si splitter cable
Post by: wpda on July 29, 2010, 01:18:37 AM
hi if i am running 2 si transducers and a splitter cable for left and right how will this effect my 2d readings? which transducer will be getting used or will both?
Title: Re: si splitter cable
Post by: IRC Kevin on July 29, 2010, 05:19:05 AM
I expect this will be the same as on my 997. Port transducer is Si only and starboard is Si, 2D and temperature. All functions seem to work fine with this setup, although there does seem to be a 'some transducers work better than others' effect. My port one is much clearer at depths over 160 feet and picks up targets at up to 220 feet, whereas the port one is very dark over 150 feet. (Can't complain as it isn't supposed to work at those depths anyway!)
Post by: wpda on July 29, 2010, 09:17:55 PM
thats great thanks for that where do you get your info from so i can try to find these things out myself
Post by: RGecy on July 29, 2010, 11:11:21 PM
Someone else asked the question and we had the guru himself "Humminbird Greg" to answer it for us!
There is a wealth of knowledge here on the forum. Browse around and use te search feature and don't be afraid to ask any question!
