Miscellaneous > Everything Else
Humminbird® Announces New Dual Spectrum CHIRP Sonar
(1/1)
newkid4si:
Published By OutdoorsFIRST Media
Published November 13, 2018
Humminbird Dual Spectrum CHIRP Sonar
Anglers can now choose the mode for their needs, delivering bigger and better fish arches, maximizing detail and target separation with Dual Spectrum CHIRP Sonar from Humminbird.
RACINE, Wis., November 12, 2018 - Humminbird® is giving anglers another advantage in finding and catching more fish with the announcement of its new Dual Spectrum CHIRP sonar, designed to deliver the best 2D sonar returns ever with minimal setting adjustments.
Through its new Low Q transducer, Humminbird allows the user to choose from multiple settings to maximize their 2D sonar based on application and goals. It is included with select new HELIX third generation (G3/G3N) and SOLIX second generation (G2) units and the new Minn Kota® Built-In MEGA Down Imaging™ trolling motors. The transducer will also be available as an aftermarket product compatible with second and third generation HELIX models and all SOLIX models.
"The easiest way to explain Dual Spectrum CHIRP Sonar is that we are providing flexibility within 2D sonar based on different frequencies and cone angles," said Justin Freeman, Humminbird product manager. "Anglers can choose Wide Mode, which delivers a wider cone angle and big, clearly defined fish arches to ensure that what you're seeing is actually a fish. Narrow Mode gives you a tighter cone angle which allows you to clearly distinguish fish, bait and structural details and provide the ultimate in target separation even when fish are tight to bottom."
Wide Mode chirps between 140 and 200 kHz and Narrow Mode chirps between 180 and 240 kHz. When combined, they work together to create the most complete 2D picture. Anglers can choose the correct mode for their style of fishing, ultimately leading to the strongest sonar returns ever in a Humminbird unit and a clear screen with minimal adjustments to sensitivity.
For more information, call Humminbird at 800-633-1468 or visit http://www.humminbird.com/.
About Humminbird
JOHNSON OUTDOORS FISHING is comprised of the Minn Kota®, Cannon® and Humminbird® brands. Minn Kota is the world's leading manufacturer of electric trolling motors, as well as a complete line of shallow water anchors, battery chargers and marine accessories. Humminbird is a leading global innovator and manufacturer of marine electronics products including fish finders, multifunction displays, autopilots, ice flashers, and premium cartography products. Cannon is the leader in controlled-depth fishing and includes a full line of downrigger products and accessories. Visit Humminbird at www.humminbird.com
JOHNSON OUTDOORS is a leading global outdoor recreation company that inspires more people to experience the awe of the great outdoors with innovative, top-quality products. The company designs, manufactures and markets a portfolio of winning, consumer-preferred brands across four categories: Watercraft, Fishing, Diving and Camping. Visit Johnson Outdoors at www.johnsonoutdoors.com
Navigation
[0] Message Index
Go to full version
