Side Imaging Forums => Helix Series Units => Topic started by: Fastcat on June 19, 2016, 07:13:59 PM
Updated to 1.210 and apparently imported some bad way points as now it is in a continuous restart mode. Thanks
My Helix10SI 'soft-bricked' last night (I edited some waypoints the night before which may have caused it, we will see...) and was able to get it starting using Humminbird's soft brick procedure and the same firmware that was loaded in the unit 1.210. Maybe I was just lucky but its worth a try, I couldn't find any other firmware versions either.
http://www.humminbird.com/Category/Support/FAQ/RebootNVR/ (http://www.humminbird.com/Category/Support/FAQ/RebootNVR/)
Good luck!
