Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: PartyMarty on June 17, 2015, 10:54:08 AM
What is the correct Transducer Select option for my setup? Various options like Quad, Dual, HD etc??
There should be high definition setting
So even though my unit is not HD, I should choose the settting that says High Definition transducer? Thanks.
Yes .... The only thing the HD designation on the unit indicates is whether it has an LED backlit screen or not.
The "HD" in the XHS 9 HDSI 180 T xducer designation simply indicates the xducer is capable of the added 800kHz SI frequency ...
The "HD" in the unit model name indicates if the unit has LED backlit screen (like Bob mentioned) ...
