Software and Software Development => Other 3rd Party Software => Topic started by: j2000 on August 06, 2012, 07:35:53 PM
Title: WTS : Strange Noise on Humviewer
Post by: j2000 on August 06, 2012, 07:35:53 PM
Hi,
I have upload to HV ,
I see clearly on Humminbird 998cx SI when i play the record...
But when i play on HV , there's is a noise...
Noise on SI or DI.
Please check on pic below..
Anybody know...what is wrong setting on HB or HV ?
Regards
Joel
Humminbird Indonesia.
Title: Re: WTS : Strange Noise on Humviewer
Post by: Rüdiger on August 07, 2012, 04:40:47 AM
Hi Joel
Are you using the same time another sonar?
It can also be interference from the electrical system (power supply). According to one possible answer sepeate use battery for power supply.
mvh
Rüdiger
Post by: j2000 on August 07, 2012, 08:06:31 AM
OMG , thanks for your info... :)
Actually when i get this pic :
We use 2 unit, Same Battery and Transducer space around 1.2 Meter , The HB we use is 998C SI and 570DI .
This very possible...i miss that thing...
Thanks Bro...
Joel
Post by: Rickard on August 07, 2012, 03:29:28 PM
j2000,
I get the same type of noise and I know it's radiated from either the engin's ignition system or charging system. I use separate batteries. The stains do not show on the display while on water because they are filtered away by the unit. Humviewer shows the raw recording so all types of disturbancies are shown. If you look carefully, you will see there is a symmetry in the stain pattern between left and right SI views.
Post by: Rüdiger on August 08, 2012, 01:41:44 PM
Hi Joel
When i use my EAGLE for DI with 85khz and my HB898 for SI in the same time, i have the same effeckt.
mvh
Rüdiger
