Side Imaging Forums => 798c SI => Topic started by: KeggER420 on March 02, 2013, 04:40:13 PM
Title: Curious: will my power cord for Matrix unit work with 798c si hd?
Post by: KeggER420 on March 02, 2013, 04:40:13 PM
It already has an inline fuse and is ran through my boat.. Will it work on the 798? It would be nice if I only had to install the transducer. Not sure it has the same PIN adapter or if it will generate the same voltage to run my 798
Thanks!
Title: Re: Curious: will my power cord for Matrix unit work with 798c si hd?
Post by: KeggER420 on March 02, 2013, 04:51:12 PM
Ahh yes I answered my own question.. Matrix used the pc10, the 789ci si hd requires the pc 11
Post by: LocDown on March 02, 2013, 09:54:48 PM
only difference between the two cables is the inline filter/choke.
Post by: KeggER420 on March 02, 2013, 11:16:06 PM
Interesting, will it hurt to use the old pc 10 to power it up at home?
Post by: LocDown on March 03, 2013, 12:12:53 AM
Nope
Post by: Humminbird_Greg on March 04, 2013, 12:47:30 PM
The wire gauge is different between these two power cables (the PC-11 having the larger current carrying gauge wire), but the 798 should not need the extra amperage and will run fine on the PC-10.  The reason the PC-11’s are packaged with the 798 units is to help prevent electrical interference from the boat’s power source on the 798 units.
