General > Frequently Asked Questions
What is HD?
(1/1)
DougV:
I have been inundated with questions about "What is HD?"
"Definition of High Definition
High Definition is largely a fluid term, taking the shape of a lot of different containers, with the only real meaning being something with a significantly increased picture quality and clarity based on the resolution of the monitor in question. For this reason, High Definition is, in reality, a synonym for high resolution.
High resolution means more pixels in your screen." From About.com
This is not bashing product by any means but to show a comparison of Pixel which equals resolution which equals HD. HD is more a buzz word in electronics and not an actual industry measurement or fact.
Comparison...
5" Screens:
798c - 640v x 640h............HDS-5 - 480v x 480h
Square Screen..................Square Screen
7" Screens:
898c - 480v x 800h...........HDS-7 - 480v x 800h
Rectangular.....................Square Screen
8" Screen:
998c - 480v x 800h..........HDS-8 - 600v x 800h
10.4" Screen:
1197c - 600v x 800h........HDS-10 - 600v x 800h
Square Screen................Square Screen
The 7" and 8" Screens are not easy to compare because of the screen physical dimension are not the the same rectangular inches versus square inches. But the 10.4" is the same resolution and size. But look at the 5" Humminbird is clearly more HD because it has more pixels....
The higher the pixels the better target separation and displaying fine data can be seen on the screen. For 2D and Down Imaging Sonar Vertical Pixels is very important because each pixel can represent less are of the water scanned. For Side Imaging Horizontal pixels is more important because each pixel can represent less area.
Here's an example of pixels I like to use. If you have 120 vertical pixels and covering 100 foot each pixel represents 12" of water. 100' x 12" = 1200" of water so each pixels represents 10". If you go to a 240 vertical pixel screen each pixel represents 5" of water. 480 pixels 2.5" of water and 640v pixels 1.875" of water.
This is why Pixels are an important part of seeing fine details like separating baitfish, small limbs on trees, etc.
Navigation
[0] Message Index
Go to full version
