Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: ficht158 on August 02, 2011, 04:26:04 PM
after i use the side imaging at say 100 on each side when i power down and then the next time i use it will default to 164 ft. i saw on here where someone said to turn off demonstration. did that and didnt change. is there a way to correct this or is this normal?
thanks
Im having the same problem.
I believe we have other posts on this also....
Robert can we search and roll these common problems together or should we keep this as is?.....
