Author Topic: Helix 7 Chirp Mega Si Mega Di G3N transducer Cable/Colored Wires  (Read 12015 times)
Offline proskeeterman@comcast.net
  • Unit(s): 997c Nav Helix 7 Si G3
  • Software: 6.300
  • Accessories: None
This is yet another added question to my inquiry about the pinched/severed transducer cable. I have peeled back the insulation on the cable and revealed multiple colored wires (six in total I Think, is that the CORRECT amount, or did I miss a color?). Can some one tell me what these colors (red, black, orange, purple, yellow and brown) control? I did find that brown and purple are Drain/ground for right n left SI channels. Just curious what the other ones are responsible for. Thanks again..
Re: Helix 7 Chirp Mega Si Mega Di G3N transducer Cable/Colored Wires
« Reply #1 on: June 05, 2020, 11:33:12 PM »
That is the MEGA SI xducer  ... I have not disected a MEGA DI cable yet  ...
Beings as your wires are cut anyway - just test ohms from each wire to each pin until you build your own pinout diagram  ...
You can definitely use the PIN number designations in the diagram I posted above - the pin designations do not change position across the HB xducers (although the wire colors going to those pins may change)  ...
« Last Edit: June 05, 2020, 11:39:48 PM by rnvinc »
  • Software: 6.300
  • Accessories: None
« Reply #2 on: June 06, 2020, 03:55:27 PM »
Ok Rickie I peeled back further on outer sleeve and here's what I've got. The wires are black, orange,red, brown, yellow and purple. Plus there's a silver wire with no covering which looking at the diagram you gave is what's called the drain/ground. When I first saw this I wasn't sure what it was because it had no cover but now with your diagram I see it. Hopefully It will go ok, if not live and learn. Thanks for the helpful info.
« Reply #3 on: June 06, 2020, 09:52:35 PM »
Your HELIX 7 MEGA SI G3N comes with the XNT 9 HW MSI 150 T  ...
The wires may follow the older color coding  ...
Last post October 04, 2017, 06:33:17 PM
by Stumpy
Last post March 26, 2018, 09:48:08 PM
Last post June 16, 2018, 01:53:20 PM
by sfw1960
Last post March 25, 2019, 02:01:28 PM
by RivRunR
Last post May 05, 2019, 10:56:54 PM
Last post September 23, 2019, 09:36:42 AM
by ezfishn
Last post April 14, 2022, 10:09:49 PM
Last post April 15, 2022, 09:46:26 PM
