Side Imaging Forums => Onix and Ion Series => Topic started by: manac on August 20, 2015, 08:50:15 AM
I have a couple questions that I can't seem to find the answer too , when using the autochart live feature and i record/map an area is there a setting I can't find that will put the depth numbers on the contours ? like a lake masters card does, all I get is lines and what highlights I put for different depths I was wanting to match some of the maps I previously made using my 998 .Will the AS GPS HS GPS receiver help give faster response time to whats happening on the map screen it seems like a very delayed response at times.
The HS GPS will give you faster response to direction changes and display what direction the boat is pointing even sitting still.
The lack of depth markers is one of the things I think Humminbird needs to fix with Autochart Live. I think the only way you can get the depth markers is to "overlay" it on a separate map card ..... You can adjust the transparency to see the mapping underneath ....I am not 100% sure, but I think this only works with a Lakemaster card.
It would be good to call customer service about this so they are hearing frustration about this from customers.
