Side Imaging Forums => 1197c SI, 1198c SI & 1199ci HD SI => Topic started by: gup72 on September 14, 2011, 08:03:43 PM
I designed this mount for the 998 side image transducer. I have had the ears break off of 3 of them last year and they are too expensive to replace. This mount allows for the mounting of a new transducer or a broken one. If your ears have broken off you can take it to a machine shop and have them install a hole 1/2" below the old one in the ears. This mount breaks away and then will reset easily with the push of a hand. The mount protests the unit by making it break away if hit from either end and takes all the stress off the ears and disperses the load of a hit through the entire body instead of just the ears. I am just seeing if there is interest in something like this, please let me know what you think!
