Our Community => Forum Info => Topic started by: RGecy on April 08, 2009, 03:46:37 PM
I added some new features to the forum today. Under your Profile menu you will see a link called "Ultimate Profile". This is basically an enhanced profile that allows you to post a little information about yourself, hobbies, pictures, favorite sites or whatever. You can also decide if you want to allow users to be able to post comments on your profile and some other settings.
I also added a way to link a Users Name to his profile in a post without having to copy and paste the link manually. Here is an example of the BBC code.
Go look at [user=rgecy]RGecy's Profile[/user] and check out the new Ultimate Profile feature on the forum.
The BBC code to make "RGecy's Profile" a link would be [*user=RGecy]Rgecy's Profile[/user] (remove the * symbol to make it work)
Or like this... [user]RGecy[/user] This is basically just the BBC code and the User Namer to link to [*user]RGecy[/user] (remove the * symbol to make it work)
Go check it out and post any questions you have.
Good Luck,
Added new feature that will allow you to preview the first post post in a topic by hovering on the link. A small box will pop up with the preview.
Added Humminbird Unit Information to the Profile Page.
You can add the Unit Owned, Software/Firmware Version Installed, and HB Accessories. The Unit Owned and Software Version will show up in your post profile.
