Software and Software Development => Other 3rd Party Software => HumViewer => Topic started by: Coach on February 15, 2017, 08:09:40 PM
I'm new on use of HumViewer. Why do some routes show up on Google Earth while others don't? As far as I can tell, the process of making the recording and using HumViewer is identical on all cases. But work and others don't.
Coach
I experimented with some of my recordings and I see the same issue ...
I haven't figured out what the difference is yet ... I will work on it some more ...
Thank you for your quick response. I hope you can find a solution.
I think the ability to use Google Earth with HumViewer is a win-win!
coach
I have found this feature to be a little buggy. Sometimes Google Earth will not refresh properly. If you close google earth and then do it again it usually works. Its more an issue when its already open showing one track and you request another.
Thank you EzyEric. You're right on!
Coach
