Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: jnordyke on October 15, 2017, 05:38:25 PM
Added new Helix units and Ethernet hub recently and repurposed my 998 to back of boat, sitting atop my catfishing rod rack. Anyone aware of an aftermarket "quick disconnect" system that incorporates the Ethernet cable - the screw-on connection is tedious to mount/dismount, and resides outside the cable management connector I have for the power, transducer, and external GPS.
Thanks in advance...
The problem is the back panel connections are different.
It is incorporated into the cable collector on later version ....99 sereies and up ..... nothing I am aware of on the 998.
