General => General Discussion => Topic started by: cfleague on April 16, 2012, 08:30:16 PM
I have down loading(export) my waypoints from my 898si onto a SD card. I put it in
my 788ci hd unit but can't figure out how to load it into my unit. I can see all the waypoints
with card in the SD slot but want to down load it onto my unit and take chip out.
When you installed that SD card into your 788ci HD unit it should have given you a message that it was loading XX number of waypoints. If you are seeing the waypoints on your 788ci HD unit than they have already been loaded into it.
Hi Greg,
Still having problems loading waypoints from sd card onto my 788cd hd. I tried this
twice thinking I may have messed things up. I put my sd card into my 898 si and asks me
if i want to load waypoints etc. on to card and hit the yes button. Takes all of about
1 second(120 waypoints). I then put it into my 788 and turn on unit. It doesn't ask me
any questions about downloading waypoints on unit, just starts showing normal operation.
The reason I seen the waypoints before is I had in interlinked from 898. My sd card has
Matrix and profile on it after exporting from 898 to sd card. Any help?
Thanks,
Dave
If it isn't alerting you with the "do you want to..." type of thing try this. Turn the unit on then insert the card. What I have to do on my 898 with the newest update to get it to give me that pop up/option.
Thanks wolfs4ever! that solved my problem
