Side Imaging Forums > Onix and Ion Series
Onix not able to read SD card with Nav data from Humminbird PC
(1/1)
aholzhausen01:
Installed my new Onix 10 CI Combo and had problems reading the LakeMaster cards. Finally started to work with no known relationship to the actions I tried. That part is working now. I then downloaded my old waypoints and tracks from my 898C SI using Humminbird PC to an SD card. I confirmed that the correct data was on the SD card in Humminbird PC. When I put it in my Onix and go to files to upload the data, my Onix doesn't see any data. When I check it says that the card does not have humminbird data. I'm wondering if I have a problem with the card reader in my Onix since I keep having these problems. Any advice out there?
Humminbird_Greg:
What is the file name and type on the SD card?
The ONIX/ION units use a *.GPX file format, so when using HummibirdPC you need to save your Nav Data as a *.GPX file and use your PC to save it to the SD card.
aholzhausen01:
Thanks Greg,
I was using the normal upload function of Humminbird PC and getting a matrix folder with DATA.HWR, 001.ht, and 000.ht files. I used the "save as" function to save the .GPX files to the card and the Onix loaded them. Problem solved.
Navigation
[0] Message Index
Go to full version
