Side Imaging Forums => What is Side Imaging Technology? => Topic started by: phmadeira on December 02, 2012, 02:13:43 PM
I know that huminbird just made a 360 scan view
but i like to know if is posible to use the side imagine as a front scaner
i tried to run it on the side but not sure of the result
any solution
thank you
phmadeira, Yes it can be done BUT looks like a bad 1940's radar screen!!
Roddy
it is hard to say what is what , when you troll the sounder on this side !!
phmadeira, Dont turn the xducer on it's side, just spin it 90' and rotate it from center 90' to each side.
Roddy
don't really sure to understand
the flat part have to be in front of the boat
so i will use only one side right of left of the transducer
like in the picture
IMG_1364_2 (http://www.flickr.com/photos/28170396@N07/8239540609/#)
i didn't thought about using the down image instead of the side imagine
phmadeira:
The side imaging comes out of the sides of the
transducer.
If you're going to try this, the bottom of
the transducer should be flat against the
water.
I guess you'd have to continually rotate the
transducer back and forth.
This is right up Rickard's and Xsilmarilsx's alley.
Hi,
I have only used SI for forward looking by first moving perpendicular to the planned direction and then entering the scanned area when it looks clear from obstacles. In this way I have sometimes checked the area close the shore before going close. But this is not a very safe method since SI doesn't really tell depth. One must learn how to detect obstacles from shadows in the image and make judgments.
The boating season is over here so I have to wait with testing another idea, tilting the transducer so the SI beams are sent forward and hit the seafloor at some distance in front of the boat. I can forsee some drawbacks with this like unstable depth reading and the lookahead will be shorter the more critical the situation is.
There is one system that seems to do this very well with SI, DrDepth's Xtools toolkit: http://www.drdepth.se/xtools.php?l=gb (http://www.drdepth.se/xtools.php?l=gb) You need a computer and a rotating device that you build yourself, plus a HB SI unit (with ethernet port, I suppose). The result seems excellent and a correct forward view is displayed in real time on the computer. I don't think the HB 360 system can do this.
