General => General Discussion => Topic started by: jbrady2852 on May 30, 2014, 08:36:46 PM
Saw a couple of recommended settings regarding Turn 83khz off for faster processing and recording. Going through the menu items on the 999ci SI I am not seeing an option to turn it off. I only see an option to change the sensitivity. Can someone point me in the right direction.
I dont have a 999 but look under the Sonar tab and choose 200 khz should be an option.
Press "Menu" 1 time ...opens Xpress Menu...(most common settings for that view)...
Press "Menu" 2 times...opens the Main tabbed menu...
Sonar tab should be the 2nd tab from the left...
Go to the Main Menu/Sonar tab and on the Beam Select box choose only 200. The choices are 200 (default), 83. 200/83.
+1
