Side Imaging Forums => 898c SI => Topic started by: geemul on August 31, 2013, 06:46:34 AM
Does the standard "out of the box" transducer do 360 degree imaging?
No.....The 360 system is a special transducer that connects to the unit as an Ethernet accessory. The current model of the 360 is a transom mount device......You will find a lot of info if you check Humminbirds website or or do some Google searching.
