Other Interest => DIY - Side Scan Sonar and towfish => Topic started by: Nitro78 on November 12, 2016, 01:33:39 PM
Does anyone have built one?
I have an side transducer from onix.
hi Nitro
I think you can made towfish for onix as same for all humminbird system.
send me in PM ref of ducer you use and i think it's possible...
Nice project.
Whe are going to a chirp towed system...may be with new helix 12 ? >:D
I am presently trying to decide what sort of sidescan to invest a few thousand in for shallow water survey work. From the pictures I have seen the imaging from the new recreational CHIRP side imaging units is as good as any of the commercial units available at any reasonable cost. What would be the maximum depth/maximum cable length that one could expect to be doable with the home-grown towfish?
Hi ropesfish
80-100m have been realized with the devices of the older generation, so would have to be possible with the devices of the latest generation.
mvh
Rüdiger
Thanks, Rudiger,
I am contemplating a Helix 12 (410380-1)
We are mostly concerned with salvage work in diver-accessible depths so I suspect that 100m of cable will certainly suffice.
Thanks, I will post updates as available.
