Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: goodwinexplorer on July 13, 2009, 08:56:19 AM
is it possible to modify the unit to view the side scan while recording?
You can view the sanning while the unit is recording.
Just start recording, exit the recording menu en then view the si view.
It says recording in the upper side of the screen.
Beware to use fast SD cards. With slower cards the view won't move anymore.
hendrik (who had the same problem)
Thanks for that it did seem pointless if you could not have you tried the sdhc cards or ultra?
regards bob ;D
It woudn't work wit standard 128MB SD.
Now I use extremeiii 8 Gb
hendrik
