General => General Discussion => Topic started by: tiburon78 on February 03, 2014, 12:38:54 PM
Hi,
A friend did a survey and sent me all data by dropbox... the thing is that I can't open it? in humminbird PC and humviewer it says that the files have error?
I guess the editing most be directly from the SD card?? or not??
Thanks!!! :-[
What file(s) did he send you and what was the file extension of each?
Are these Sonar Recordings?
Hi,
I got .IDX och .SON in a archive and .DAT and .XML in Another....
He's sent you a Recording.
A recording should be a folder containing for example:
A folder called R00102
A file called R00102.DAT
The R00102 folder will contain .SON and .IDX files:
B001.SON, B001.IDX
B002.SON, B002.IDX
. . . etc
The FOLDER and the .DAT file must be matching names.
I believe the .XML is created after Hummview has opened and process this data.
Hopefully he has archived the top-level folder:
Folder <--- Archive and send this folder
R00101 folder
R00101.DAT
R00101.XML
Thus expanding & recreating the file-structure is a little easier.
[attach=1]
Hi!! yes I got those files!! How do I look at the sonar files??
I use HumViewer.
http://forums.sideimagingsoft.com/index.php?topic=172.0 (http://forums.sideimagingsoft.com/index.php?topic=172.0)
<file>, <open>, and select the *.DAT file
I use HumViewer.
[url]http://forums.sideimagingsoft.com/index.php?topic=172.0[/url] ([url]http://forums.sideimagingsoft.com/index.php?topic=172.0[/url])
As Salado says. But you might wish to always first do: Settings-->Unit Settings cause the defaults always meters.
