General => General Discussion => Topic started by: wnutt on July 05, 2018, 04:37:37 AM
998 si will power up but no sonar or side scan. Tried demo mode and the same no sonar but down and side scan work in demo mode. software is up to date
Have you tried Restore Defaults under the Setup tab ..??
Can you crosstest with another xducer on your head unit or another head unit on your xducer ...??
I have restored defaults and swapped out head unit with 898 and that unit works on the transducer. Any other ideas as hummingbird does not support the 998 si any longer.
Some have had success back dating the software to an older version ...
It is recommended not to backdate the software to an older version than the unit came with ...
Here is some of the older versions ...
http://forums.sideimagingsoft.com/index.php?topic=85.0 (http://forums.sideimagingsoft.com/index.php?topic=85.0)
