General => General Discussion => Topic started by: sdtransplant on May 28, 2019, 07:19:48 PM
Title: i pilot not connected
Post by: sdtransplant on May 28, 2019, 07:19:48 PM
1199cihdsi @console 859hd @ the bow with the ethernet box , checked to see if power to hub it has power, but when I go to the system check on both graphs it shows I pilot not connected checked all cables they are tight. they are linked (supposedly) to a terrova . just updated both graphs What am I doing wrong?
Title: Re: i pilot not connected
Post by: FishinLite on May 29, 2019, 08:03:19 AM
Is your terrova turned on? Can you operate it from your remote or foot pedal?
Post by: sdtransplant on May 29, 2019, 09:00:50 AM
have the terrova deployed and on, I can operate it either with the remote or the foot pedal
Post by: ezfishn on May 29, 2019, 10:50:38 AM
If you're seeing both units under Network, try connecting Link direct to one of the units.  If that works then may want to try a different port on the switch.
Post by: sdtransplant on May 29, 2019, 01:12:57 PM
can't even find network on any of the menus
Post by: ezfishn on May 30, 2019, 12:14:03 AM
If you aren't getting a Network menu then no network is being established.  Verify both units are running compatible software versions.  Try the following procedure to reset the IP Address:
1.  Power both units up, and once they are fully booted and running, DISCONNECT both your Ethernet connections while powered, reset defaults - and shut down.
2.  Power both back up and make sure they have been running several minutes to ensure they are fully booted and reset defaults once again.
3.  Shut down a second time - before you boot each back up again,reconnect the ethernet cables and turn both units back on.
Or, connect both units direct with ethernet cable (bypassing the switch) to determine if ethernet switch is bad.
Post by: sdtransplant on May 30, 2019, 11:36:48 AM
think I have a bad ethernet hub if I run the tm to the 859 direct everything comes up
Post by: ezfishn on May 30, 2019, 11:59:26 AM
Sounds like the switch if it worked with the direct hookup.  Might try different ports on switch.
Post by: sdtransplant on May 30, 2019, 02:14:52 PM
will try different ports and thanks for the help
Post by: FishinLite on May 31, 2019, 08:34:47 AM
I know this sounds like a dumb question, but is the Ethernet switch powered up.
It has some mighty fine wires connecting it to the power.
Post by: ezfishn on May 31, 2019, 12:45:11 PM
According to original post, power was checked.  Good point though because it is a potential single point failure in a network with multiple units/accessories.
