General => General Discussion => Topic started by: bubbacolson on January 20, 2015, 02:25:26 PM
I just downloaded humviewer 86 and when I take a snapshot it only shows the left side of the image. How do I set to show both sides. Attached pics
Place your cursor on the picture. Right click, select View, select SI Both... Chuck
Chuck, I do have it set on si-both and you can see both on the screen in humview but when you click on save snapshot it only takes a pic. of the left side. Thanks
wow, don't know. It works ok on my viewer. Hmmmmmmmmm Chuck
Interesting ...
The image you posted above ... Is this a PC "screensave" using the screensave button on a Windows keyboard ... Or is this a posting from the image ".png" that was saved on your PC ...??
This image was made by humview, I stopped the recording and when to top right File and chose save image, it ask if you want to hide gps then it saves the image as a jpeg. Attached is one taken in 3view.
You might want to uninstall humviewer and then reinstall. If you stopped the playback and choose top/right you should have only seen the SI scan. The picture you posted is SI, DI and TrackPlot usually found in 3 view. it also looks like the 3 view standard screen has the top left selected at DI and not the default 2D.
