Other Humminbird Products => Accessories => Topic started by: wconn1979 on May 13, 2015, 09:47:46 PM
I have the TM mounted 360 hooked directly into an onix 8 si. Does the internal gps antenna on the onix work for the 360 or do i need to install the gps antenna included with the 360.
Definetly! GPS puck that came with your 360 has a heading sensor built in that the 360 needs for orientantion in the water, also puck has a small arrow on it the need to be mounted with rarrow pointing to the cront of the boat.
Well that blows i need to find the cable to connect it to my 360 then. The included cable does not connect to the onix 8.
