Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: Gimp on October 01, 2013, 06:47:12 PM
Anyone know if I can plug the Humminbird Ice Transducer Xi 9 20 into my 998 HD so I can use it this winter without trying to stuff my big HD transducer down the hole. I know I would have to switch the menu to the dual beam option, but does the plug match up?
yes
http://store.humminbird.com/products/314001/XI_9_20 (http://store.humminbird.com/products/314001/XI_9_20)
Ttf is correct. Even though the 998 is not listed; it is compatible with the XI-9-20 transducer. You will need to force the unit into the Normal operations mode when using it or turn off the Demonstration menu.
Thanks fellas. The help is appreciated.
Tried it out on Monday and it works great. Thanks again fellas.
