Side Imaging Forums => Helix Series Units => Topic started by: Tatersalad on April 07, 2018, 11:46:03 AM
I'm wondering if anyone has experienced this? My Helix 10 SI is usually on and in the start-up screen (the one that says press exit) when I remove the screen cover. I have been careful when putting on the cover so as to not push in the area of the on/off button and usually pull the top of the cover off to check that it is off before tarping my boat. The next time I remove the cover it is turned on.
I have it connected direct to the starting battery and the battery has a single bank Minn Kota onboard charger connected and plugged in while in storage. Battery is always fully charged. Boat is tarped and under carport when not in use.
Right now I have it with the bottom right corner of cover not fully pressed on. I'll have to check it when it warms up a little.
Any one with any ideas or similar experiences.
Tater
I've only seen it a couple of times because of the cover. If the issue is only happening during storage then maybe a battery cutoff switch to isolate battery from the boat during charging. I have a cutoff switch for both the cranking and TM batteries so now I never put the cover on until I know the cut-off switch is turned off. Haven't seen any corrective measures for the cover but maybe someone else knows a different cure.
All my electronics are on a dedicated battery in my console. Positive on the battery goes to a breaker on the dash then to a switch beside the breaker then to the buss bar. I kill all power going to all electronics at the end of a day fishing as soon as the boat is on the trailed. I too have had mine turn on when putting the cover on. Don
Had same problem.
installed a on off battery switch.
Bob
Thanks for the replies, now I know I'm not alone having this happen. I'll get it taken care of.
Tater
I have modified the rubber cover by gluing a rubber O-ring around the area (inside the cover) that touches the power button ...
This created a bumper (of sorts) around the power button to keep the rubber cover from pressing against the power button ...
That is a clever, simple and effective solution. What type of glue did you use for the rubber/plastic bond?
Goop Marine adhesive ...
thanks
