Side Imaging Forums > 598c SI HD
gr16/4 gps on 597c
mcbillw@gmail.com:
need info/schematic or pin out on the actual receiver where wires plug in, damaged mount and wire, and I have everything put together but there are two identical plugs with diff colors, need to know the left to right colors, or which plug goes left and right, black & red and white and green, what is order? any info appreciated, have looked every where in support & can't find that info...mcbillw
sonar2000:
Here is the link to the receiver manual. See if this helps..
Look at page 2, 3 and 4....
http://www.humminbird.com/PDF/AS_GR16.pdf
Humminbird_Greg:
mcbillw,
Are you talking about the plugs that are internal in the unit or the GPS Receiver’s connection plug? Pictures used to be worth a thousand words before inflation but are still good at clarifying what you need to know.
sonar2000:
A picture is still worth a thousand words. Inflation does not change the picture. the wires and cable are the same..
In a nutshell the GPS receiver has a wire that comes out of it and goes to a connector that connects to the unit.
The connector at the unit end of the cable has a pigtale cable to link another nema device sentence. The wires are common in the cable end that plugs into the unit.
Where exactly did you break the wire and did you break any connector??????
chuck
Humminbird_Greg:
The damage was to the GPS Receiver cable.
mcbillw was hoping to just reattach the cable to the PCB inside the GPS Receiver but the cables are epoxied in place so that they do not leak. There are two sets of connectors inside and they are labeled and so he wanted to know the correct connection for these.
Navigation
[0] Message Index
[#] Next page
Go to full version
