Side Imaging Forums => Helix Series Units => Topic started by: gaj on June 05, 2018, 07:29:31 AM
I want my helix 10s to share waypoints what do I need?
If there's only 2 units ...:
You will need an Ethernet adapter cable for each unit ...
https://humminbird.johnsonoutdoors.com/accessories/cables/ec-qde-ethernet-adapter-cable
And you will need an Ethernet cable long enough to reach ...
https://humminbird.johnsonoutdoors.com/accessories/cables?facets=7319%2C
If there are additional Ethernet devices - you will also need the Ethernet switch (hub) ...
https://humminbird.johnsonoutdoors.com/accessories/boat-navigation/eth-5pxg-5-port-ethernet-switch
Then you would need an Ethernet cable from each device to the Ethernet switch (hub) ...
