Author Topic: Extracting GPS & Depth from Humminbird SONAR files  (Read 8195 times)
Offline MikeM24108
  • Unit(s): HELIX 5 CHIRP SI GPS G2 | HELIX 5 Series
  • Software: Not sure - current
  • Accessories: None
« on: October 08, 2017, 06:25:07 PM »
I have a Humminbird HELIX 5 CHIRP SI GPS G2 and I'm doing some fresh water (limnology) marine archaeology with associated lake mapping.  I have searched, but can't find a method of extracting the LAT, LONG, DEPTH info from the Humminbird SONAR files.  I need to get this in some type of ASCII format (CSV, etc., even unformatted if only available) so that I can import it to EXCEL and modify data for subsequent export to a more sophisticated scientific contouring program.
Does anyone know where I can find a 3rd party software that can do this extraction.  I can deal with extracting more info than the needed LAT/LONG/DEPTH data in Excel ... but it is really only the LAT/LONG/DEPTH that I want.  I called Humminbird tech support and they said it is not available from their proprietary format.  I find this hard to believe as folks like Navionics certainly extract it.
Appreciate any help or links or suggestions on how I can extract this data from the Humminbird SONAR files for subsequent use.
Offline Rüdiger
Re: Extracting GPS & Depth from Humminbird SONAR files
« Reply #1 on: October 14, 2017, 04:47:02 AM »
Hi Mike
Welcome to the forum :)
Possibly this is possible with the help of the HumViewer software. Water depth and position data are  from the boat but not from the sonartarget.
mvh
Rüdiger
Offline Nitro78
  • French frog
  • French frog!
  • Unit(s): Solix mega
  • Accessories: TM265 LH + 2 side imagin transdeucer an
« Reply #2 on: October 16, 2017, 12:05:57 AM »
You can use Reefmaster for that !
Offline ckd022
  • Unit(s): 798ci SI Combo
  • Software: 5.840
« Reply #3 on: October 17, 2017, 08:00:10 PM »
Humviewer will export lat/lon, date/time, depth, speed and heading to a csv file IF it can read the sonar files for your unit.  I have a 738SI that I have successfully done this with.  One caveat, if I remember correctly, csv export was broken in the latest release.  I believe you need version 67 for that feature to work.  If you need a copy, PM me and I'll send you the one I have.  I have gotten it to work with Win XP, Win7 and Win10 in the past.
Kevin
Last post August 09, 2009, 05:37:08 AM
by Jolly Roger
Last post September 13, 2009, 11:39:21 AM
by Wall-E-Baiter
Last post September 11, 2009, 10:30:57 AM
Last post June 04, 2012, 08:31:34 AM
by kucai
Last post August 06, 2012, 03:15:31 PM
by lajo1976
Last post February 10, 2015, 03:11:54 AM
by peterv6i
Last post January 17, 2019, 07:53:33 PM
Last post May 04, 2023, 12:19:45 AM
by Walter
