Side Imaging Forums > 898c SI
Linking 3 units
(1/1)
362 ranger pilot:
I have a 899 and 859 link together via eithernet  now. I am wanting to add a 3rd unit mainly for gps navigation  at the console so I can have 2 full screens instead of running split screen on 1 unit.  So I would be able to see more detail on each unit.
My thoughts where to add another 859  head unit and run it off  the 899  transducer via eithernet.
can I link all 3 units together this way? for saving my way points? What would be needed to do this?
Bob B:
You will need a 5 port Ethernet switch .... and will connect all units to it.   http://www.humminbird.com/Products/AS-ETH-5PXG/
Best way to back up waypoint is to export nav data to a 35Gb or less SD card and bring them into Humminbird PC
362 ranger pilot:
Thanks for the reply
I back everything up on ad cards
I'm just looking at other options on  seeing my god and mapping while also seeing sonar  while running
gaj:
I have two 899 SI units that I would like to link together. Not sure what additional cables I need to accomplish this
rnvinc:
--- Quote from: gaj on September 10, 2017, 04:32:43 PM ---I have two 899 SI units that I would like to link together. Not sure what additional cables I need to accomplish this
--- End quote ---
For connecting two single xx9 series units you will need an AS EC QDE adapter for each unit (2 total)  ...
https://www.humminbird.com/productDetail-Accessory.aspx?Pageid=728&id=868
(Note: the AS EC QDE cables are ~ 1ft long)  ...
And you will need an Ethernet cable (1 total) long enough to reach  ...
https://www.humminbird.com/productCategory.aspx?id=3774&facets=7319,
Navigation
[0] Message Index
Go to full version
