General => General Discussion => Topic started by: graggy on April 08, 2015, 05:44:14 AM
Not sure what all I need to order if I buy the 1199ci HD SI. Does it come with the gimbal mount or cable management system?
It has everything you need to start fishing except the battery ...and a mapping card if you want better mapping detail than the Contour XD internal mapping ...
Head unit, power cord, xducer, xducer transom mounting hardware, gimbal mount, cable collector, sun cover ...
GPS antenna is internal ...
What are you meaning by "cable management system"?
The cable collector that Rickie mentioned above holds the connectors of the cables (power, transducer and Ethernet of you buy that cable) so that they are all aligned and plug into/out of the unit at the same time. There is no cable 'loom' or covering for the rest of the cables, if that is what you are asking about.
Yes the cable collector is what I meant
