Side Imaging Forums => Helix Series Units => Topic started by: cwenbass on April 18, 2017, 07:21:15 AM
Title: Helix 7 SI reading inconsistent depths
Post by: cwenbass on April 18, 2017, 07:21:15 AM
Got a new helix 7 SI. Swapped out and upgraded to XTM HDSI trolling motor transducer. Used it first time yesterday and worked great. Went out today for a few hours and after about an hour, got different depth readings going from 2 to 9, to 91, to 321, back to 2. All over. Then it appeared to work again right before I pulled boat out. Any ideas?
Title: Re: Helix 7 SI reading inconsistent depths
Post by: rnvinc on April 18, 2017, 11:01:02 AM
Erratic shallow water depth seems to be reported often in the forums right now  ...
The common consensus right now is to use SwitchFire Clear and reduce Sensitivity  ...
