Side Imaging Forums => 997c SI, 998c SI & 999ci HD SI => Topic started by: junoir on April 19, 2013, 06:44:07 AM
happens far bit in deeper water maybe somwthing to put in next update
Could you explain what you are meaning by “the graph coming out”?
It looks like the unit is showing some sort of interference. Was there another sonar unit running at the same time?
What transducer was in use when you made this screen snapshot?
Does this happen with the motor and all other electrical devices turned off?
im running the tm260 transducer the snap shoot was taken on a drift so no motor just vhf radio and a garmin gps and by graph i was just meaning the way the depth lines are
“tm260 transducer” is that the Airmar transducer? I have no experience with this transducer.
I would try shutting off all electrical devices and see if it goes away or not
yep its airmar
thanks i have a play around next time it does it only seems to do it in 900ft+
What Beam Select menu setting are you using?
just 50khz
